Vito0163
Feb 20, 2026Aspirant
Orbi 960 10gb port not reading high fiber speeds correctly
Orbi 960 10gb port not reading my 8gb fiber speeds. The max it will read is 5 gb down and 3700 up. I have tested it other ways using another router (eero max7) and directly out of the modem and eve...
Vito0163
Orbi firm 7.2.8.2
optimum 6e max router fiber 8gb service
brand new cat 6a cables connected
on board orbi test is 4.7 to 5gb down and 3.7 gb up
I have tested with the optimums techs tester connected directly from the modem connected with the cat6- cable.
I have also went out and purchased the new eero max 7 and connected to the fiber modem and tested the speed using the app through eero which read 7.8 up and down. I also connected the 10 fb port from the eero to a 10 gb adapter to a mac and read 7.8 up and down.
Everything is is reading the same speed except the orbi 10 gb port
