MikeArmadillos's avatar
Nov 13, 2022
Orbi 960 IoT Issues
Hi All,
I have an Orbi 960, 1 router, 2 satellights, and I have been having issues with the IoT network,
Item's disconnecting, up until now a router reboot would solve the issue, now the IoT network is not visible, and when I try an connect to it say's network not found although in the Orbi app its shows some of the devices as connected ??,
Steps Taken so far
Updated Firm ware on all Obi units
Changed Wifi Channel
Turned off IoT rebooted Turned back on again rebooted
I have had numerous calls with Tech Support
when I first got it the IoT network was displaying all the time so it was easy to add smart devices like Lamps, Plug's, Heaters, Thermostats, but if can't see the network for my Phone or Tablet to join I then can't add the devices, I have tried connecting whilst my phone is connected to the main network, with no luck, The Network names are the same Iot just has -IoT at the end .
thanks for any help
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • MikeArmadillos's avatar
      MikeArmadillos
      HI, FURRYe38,
      thanks for helping out NG tech are now sending a replacement router, as it’s broadcasting IoT intermittently, but the out 2 networks are ok, it may also be that one safelight is not broadcasting 2.4ghz but that’s the next step, after this post i did some investigations and found it i could get IoT now and again next to the router and  the other safelight.
      As for info request each unit is about 30 meters apart
      as for firmware it was the latest version the rolled back 2 versions
      also Chanel’s we have tried various
      as for other WiFi we see a couple of networks at different points of the house
      ISP Virgin Media with super hub 3 but its in modem only mode
      have tried several resets
      will update when i get the replacement router
      thanks again
      • FURRYe38's avatar
        Ok sounds good.
        30 meters maybe a bit too far apart. 12-15 Meters maybe a better starting point.
