johnstg2011
Jul 13, 2026Aspirant
Orbi 960 not obtaing a DHCP address from upstream carrier 5G modem/router.
I'm having issues with an ORBI 960. Details of the ORBI router are; Hardware Version RBRE960 Firmware Version V7.2.7.15_5.1.16 GUI Language Versi...
HappyCat
Jul 14, 2026Luminary
and......... the prize for most unexpected discovery has been won! We have all been led to believe that "newer is always better".
Ha!
Thanks for reporting these results.
johnstg2011
Jul 14, 2026Aspirant
Of course, the next question is, why? Neither CAT6 or CAT7 ethernet cables have any smarts in them, CAT7 has individual pair shielding, and shielded jacks, I can't see any of that making a work/no work difference for a device to device on a 90cm patch cable. But the evidence suggests otherwise.
And these were not ebay/Tempu elcheepo hit or miss cables, I only use commercial grade cables from a major cabling wholesaler.
- StephenBJul 15, 2026Guru - Experienced User
Is it possible that the connector isn't fully seated into the 960 socket?
- HappyCatJul 15, 2026Luminary
This is correct, no "smarts". However, electrical cables have electrical characteristics. As the Wikipedia article pointed out, there is a LOT going on between the two Ethernet adapters. The Nokia is saying, "I can do gigabit, 100megabit, 10 megabit" and the Orbi is saying, "I can do a whole bunch of different speeds". And they are both sending and listening for those mysterious link integrity signals.
There is probably an engineer somewhere within Netgear who understands autonegotiation and how Netgear's multi-speed Ethernet adapters interact with other brands. (Unless the Ethernet adapters have been 'contracted out' to another company.)
I have vague memories of other reports on the Forum concerning higher speed ISP connections not working correctly. (i.e. when the ISP offers multi-gigabit and the Netgear router does not sync correctly.)
It seems rather unlikely that the autonegotiation would work with a good cat 6 cable, but fail with a good cat 7 cable.
There could be a grounding issue in the modem (or router I guess). That would be masked by an unshielded cat 6 cable. If the shield isn't grounded properly, it acts like an antenna, which will create problems.
Since cat 7 is much stiffer, I am still wondering if the connector simply isn't fully seated into one of the sockets.
Although this is interesting to explore more, I think the simple solution is for johnstg2011 to just use the cat 6 cable. It can handle 10 gbps, and a short patch cable really doesn't need to be shielded.
