Frankpjr
Oct 15, 2026Aspirant
ORBI 960 Strange Issues
I have had this system working well for almost 2 years but today a good part of my network is not functioning. First in the web interface it shows the 2 satellites disconnected but I can put the IP a...
Oct 16, 2026Guru - Experienced User
How are the RBS ethernet connected to the RBR? Directly behind the RBR or is there any kind of LAN switch or LAN patch panel in between?
What channels are you using on the RBR?
I just had my 850 series online with FW v7.2.8.8 on and was working well aside IPv6.
- FrankpjrOct 16, 2026Aspirant
I was using cable but the cable goes under ground and issue happened with cable so now using wireless connection to satellites
