NickUrso
Aug 22, 2023Aspirant
Orbi 960
Hello, we are installing fiber at our locations and the provider is asking does the router use single or mutli-mode fiber on the 10G port?
thanks
The router WAN port connects to the Optical Fiber Termination (ONT) with Ethernet cable.
which is included in the box:
https://www.downloads.netgear.com/files/GDC/RBRE960/RBRE960_TS.pdf
- NickUrsoAspirant
Does it use MMF or SMF
The 960 doesn't support Fiber optical input connections, only RJ45 10Gb ethernet cable port jack.
The ISP should provide a ONT that converts there Fiber optics to ethernet connection.
