lisakc's avatar
lisakc
Tutor
Apr 12, 2022
Orbi 960E will not connect to Netgear CM1150V modem
Orbi has always been a breeze to setup until today, just received my super spendy Orbi 960E Connected the router to the Xfinity netgear modem, CM 1150V and the link light would not go on on the modem and I could not get an internet connection. Yes, I reset everything several times to no avail. Tried to contact support, was on hold for over an hour before I gave up. Did I get a lemon or is something else going on? I seriously hate calling support.
  • What link light?
    Is anything else plugged into the cm1150v? Reason I ask is xfinity only supports 1 public ip address. meaning only 1 device can be connected to it.
    If there was, power off the cm1150v and the router and disconnect everything from both. (even coax from modem)
    Wait a couple minutes.
    then connect coax back to modem and power it on.
    wait a couple minutes for it to boot.
    then connect port 1 on the modem to the wan port on the router.
    then boot the router and wait a few minutes for it to fully boot.
    then try setup.
  • plemans's avatar
    What link light?
    then try setup.
    • lisakc's avatar
      lisakc
      Tutor
      Thank you I had to connect the modem without connecting anything else to the ethernet ports, it works now!
      • plemans's avatar
        Glad you got it working!
        Its a crappy thing that xfinity does by limiting modems to only 1 public ip address unless you pay for more or have a business class line. I wish that they did a better job of letting users know that for devices like the cm1150v/cm1200
