Spezaled
Apr 07, 2020Tutor
Orbi AX 6000 and AT&T fiber gateway issue
I recently purchased the Orbi with WIFI 6 and planned on using them in AP mode to extend my U-verse Fiber gateway modem signal. Got the WiFi set up just fine but now my U-verse TV signal locks up afte...
- Apr 09, 2020So AT&T came out and configured the gateway so that it all works now. They kept the tv feeds going to the gateway, set it to IP pass through and turned off he WiFi. The Orbi had to be set to router mode, not AP mode because of an IP conflict. Everything is running again.
Apr 08, 2020Guru - Experienced User
You can use the IP pass thru if you want to use the Orbi in router mode.
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
If you configure AP mode on the RBR, then IP pass thru isn't needed.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Spezaled wrote:
I recently purchased the Orbi with WIFI 6 and planned on using them in AP mode to extend my U-verse Fiber gateway modem signal. Got the WiFi set up just fine but now my U-verse TV signal locks up after 10 seconds and then loses signal altogether. Has anyone else had this issue and is there an easy solution? I know there’s the IP pass through but I’m uncertain on how to properly set it up. FYI, I have many Ethernet cables current connected to my gateway. I’d hate to return these new units.
