sutset
Jan 05, 2020Guide
Orbi ax drops all 2.4 connection every 5 to 7 days
All my 2.4 connections both router and satellite drop every 5 to 7 days. A reboot always brings them back. Anyone else having this issue? This has been going on since latest software was installed.
- RyoWongAspirant
Orbi ax drops all 2.4 connection every 5 to 7 days x 2
- KMDonlonVirtuosoYes, seems to drop my Trane XL824 thermostat every 4 days or so. Thought it was just me.
- ForevermoreAspirant
It is happening to me as well. Power cycling the satellite is the only thing that seems to resolve it, but only temporarily. In about a week or less it's dead again and have to recycle it again. It's getting very annoying. Never had any issues like this with my old Orbi.
- sutsetGuide
So support told me for 2.4 to always use channel 11. So I changed it from auto to 11 and mine has dropped again. But it has only been 4 days or so. A new software was released today support for multi satellites and bunch of bug fixes. I notice that my devices have stronger signals after upgrade.
- FarmerBob1Luminary
sutset wrote:So support told me for 2.4 to always use channel 11. So I changed it from auto to 11 and mine has dropped again. But it has only been 4 days or so. A new software was released today support for multi satellites and bunch of bug fixes. I notice that my devices have stronger signals after upgrade.
What version was the new release?
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
sutset wrote:All my 2.4 connections both router and satellite drop every 5 to 7 days. A reboot always brings them back. Anyone else having this issue? This has been going on since latest software was installed.
