gglazer
Jun 09, 2021Aspirant
ORBI AX with Surfboard
Looking at getting an Orbi because the current router doesn't reach some parts of the house.
However, we currently have an Arris Surfboard SVG248AC which is both modem AND router. So, if I plug the Orbi into the Surfboard, I'm not just plugging it into a modem, I'm plugging a router into a router. Will this configuration work or will I need to figure out how to turn the Surfboard's router functionality off or buy a modem only unit?
Thanks,
Glenn
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Couple of options,
