Talon38's avatar
Talon38
Tutor
Dec 17, 2022
ORBI AX11000 SYSTEM AND EXTENSION QUESTIONS
Greetings!  I have 5 Orbi RB960Bs in my home working well together.  We are building a dock around 130' from the house and have run a Cat 8 cable to the dock to set up Wi-Fi.  What device might we connect at the dock to extend our wifi from the house to that area?  Is that possible.  Any help would be appreciated.
  • FURRYe38's avatar
    Could just add any ol wireless AP, RBS or a wifi router set to AP mode and connect it to that lan cable running from the home to this area...
    • Talon38's avatar
      Talon38
      Tutor
      Thanks!  I've purchased a WAX630-EP.  Maybe overkill?
      Mike
      • CrimpOn's avatar
        CrimpOn
        Talon38 wrote:
        Maybe overkill?
        Probably.  Mixing residential and commercial products may be more complicated than you want.
        In addition to the Ethernet connection, it might be useful to consider:
        • How the unit will be powered?
        • How the unit will be mounted?
        • Does it need to be weather resistant?
