JackMurray's avatar
Jan 12, 2023
Orbi AX1800 WiFi 6 Dual-band Mesh Router(RBR350)
Hi,
I have an Orbi AX1800 WiFi 6 Dual-band Mesh Router(RBR350).
Can I buy additional routers to add to my system?
  • plemans's avatar
    Satellites, yes.
    routers: no.
    the routers don't integrate (can still be used in AP mode) but the satellites do
    • JackMurray's avatar
      JackMurray
      Tutor
      Thanks for this. I'm not technical. Do I need to buy extra equipment?
      • plemans's avatar
        Isn't that what you were looking for? Adding more coverage? But you were planning on doing it with adding routers.
        You want to add satellites. They'd be RBS350 models.
        Or what are you trying to do?
