jsanni
Jul 15, 2021Aspirant
Orbi AX4200 Doesn't Reconnect Most Devices After Reboot
Hello,
I own a Netgear Orbi AX4200/CBR750 which is a modem/router combo and it is running on the latest firmware. I typically have about 30-40 devices connected to the router, and it was working fine for the last few days. I just unplugged the router and moved it to a different location, and now the majority of the devices originally connected refuse to reconnect. I know the router is working, as there are about 2 devices connected via wifi right now (including the laptop I'm typing this on), but everything else refuses to connect, including the one sattelite I have for the router. I really don't want to factory reset the router if at all possible. Any suggestions? Thanks in advance!
Here is some extra info:
- I have the router in a 2800 sq ft house
- My ISP is XFinity
- The outer and sattelite are about 25-30 ft away from each other
- The model of the modem/router is the Orbi CBR750 or AX4200
\30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Power OFF the RBS. Remove the RBS from the RBRs connected clients page. Power ON the RBS. Press the sync button on the RBS then on the RBR and re-sync the RBS to the RBR.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings on the RBR.
- jsanniAspirant
Hello, I have firmware version
V3.2.18.2_1.4.14
I have tried the suggestions to no avail. I have my laptop now connected to the router via ethernet, and after restarting the router, my laptop is the only device connected. I have a next door neighbor using wifi.
A factory reset and set up from scratch will be your next step.
