bgrg2000
Apr 19, 2020Aspirant
Orbi AX4200 RBS750 Satellite
I recently puchased the Orbi AX4200 in an effort to equalize the WiFi strength in my home. My ISP (Windsream) is terrible and provides poor speeds (18mbps) but I was hoping to cover the house with at least the same poor speed but many times the satellite just doesn't seem to be working so I think it is to far from the router. The RBR750 is conected via Eithernet wire to the Windstram modem. The RBS750 Satellite is currently about 50' away from the router but with only about 2 walls inbetween. Is it possible to purchase another RBS750 to add a second satellite? Is there a way to measure signal output from the satellite?
Try moving the RBS closer? 50" maybe a bit too far...Try 40 feet.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Any Wifi Neighbors near by? If so, how many?
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2346. Reboot both RBR and wireless devices. Under Advanced Tab/Advanced Settings/Wireless Settings
- bgrg2000Aspirant
1) I moved the Satellite to 30' away from the router
2) Firmware says it is up todate but its number is:V3.2.10.10_1.2.12
3) ISP Modem: Windstream Wi-Fi Modem - T3200
4) NO actual neighbors. The Windstream WiFi is on and a foot from the NG. Also the Ring WiFi is on and about a foot on the otherside of the NG from the Windstream modem. The Ring is running off the Windstream modem via WiFi. Should it be running off the NG? There is also a Nexia Home Hub runing a few Z-wave devices that is directly connected to the NG via Ethernet cable.
5) No clue how to do this, I can't find an advanced tab on the Orbi App
bgrg2000 wrote:Try moving the RBS closer? 50" maybe a bit too far...Try 40 feet.
What mode is this modem working in? Router or Bridge? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopAny Wifi Neighbors near by? If so, how many?
Wifi on the modem needs to be disabled fully. Having the modem close to the RBR with both wifi going will be problematic.
Possible noise and interference near the source RBR is causing the RBS to not work well.
Use a PC or laptop and a web browser to make changes to the RBR.
