BigSOB's avatar
BigSOB
Orbi AX4200 Router and AX4200 Satellite - Can you disable Microphone
Is it possible to disable the microphones on the Orbi AX4200 Router and AX4200 Satellite devices?
Thanks!
  • FURRYe38's avatar
    Microphone? I :smileywink: don't believe there is anything of the kind on network routers...
    • BigSOB's avatar
      BigSOB
      Maybe I am missunderstnding this feature on the website:
      • Works with Amazon Alexa and the Google Assistant so you can use voice commands to control your home WiFi network.
      So, the unit itself doesnt have a microphone and doesnt have Alexa or Google Assistant capabilities? I thought I read someone was having issues with those features.
      Thanks,
      Justin
      • FURRYe38's avatar
        Ya the Orbi doesn't have a microphone. I may work with Alexa enabled devices like Echo Dots or if you install a RBS40v which V is for Voice. Otherwise the Orbi AX itself is just a wifi system only. No Voice.
