SueBray
Oct 16, 2023Aspirant
Orbi AX4200 Tri-Band Mesh WiFi 6 System compatible with which Netgear Outdoor extender?
We have a home that has the Orbi AX4200 Tri-Band Mesh WiFi 6 System installed. We need an outdoor wireless extender that can work with that system. And, we cannot run any cabling, except to plug in t...
- Oct 16, 2023
If you have the v2 model of the RBS50Y:
Oct 16, 2023Guru - Experienced User
If you can get the extender mode FW loaded on the RBS50Y, it could work with the Orbi AX system. Otherwise, there isn't any new AX NG out door extenders available. Might check out some 3rd party Mfrs to see if they have any outdoor rated extenders.
