ahmedoozziee
Sep 10, 2025Aspirant
Orbi AX4200 WiFi 6 High-Performance Router for Ooredoo (RBR750 (Ooredoo))
i've bought a used Orbi AX4200 WiFi 6 High-Performance Router for Ooredoo (RBR750 (Ooredoo)), I want to flash it with stock firmware.
CrimpOn
Sep 10, 2025Guru - Experienced User
Netgear firmware for the RBR750 and satellites is here:
https://kb.netgear.com/000066598
The recommended procedure is to manually install firmware on the satellites first, and then install on the router last.
- ahmedoozzieeSep 10, 2025Aspirant
ThanksCrimpOn for your response, This will unlock the router ?
