fjsj_168
Jan 29, 2024Tutor
Orbi AX4200 WiFi 6 High-Performance Router (RBR750) -Firmware V7.2.6.21 router issues
Greetings, I am having an issue when upgrading my system from FW version V4.6.14.3_2.3.12 to V7.2.6.21. My configuration is the router is in AP mode, connected to a Verizon FiOS router, and the 2 R...
Jan 29, 2024Guru - Experienced User
What browser did you use to apply the FW to the RBR after the RBS were updated?
Did you power OFF the RBR and RBS for 1 minute then back ON to see if the system returned to normal?
How is the RBR configured for AP mode? Dynamic or Static AP configuration? Possible that the Dynamic configuration was working then after a reboot the Verizon router change the IP address or something.
Something you might try, if you have the FW files on your wired PC, change the RBR to router mode and disconnect it from the Verizon router temporarily. Then reupdate the RBR back to v.21 FW using the RBR FW file. After the RBR is back to v.21, power it OFF then back ON. After it's ready, make sure your two RBS are connecting and fully synced. If you can get to this point, then configure the RBR back to AP mode and reconnect the RBR using it's yellow WAN port to connect to the Verizon routers LAN port.
I would set up the RBR as suggested in the attached PDF AP mode process for static IP address configuration.
fjsj_168
Jan 29, 2024Tutor
Thanks for the response FURRYe38,
Since I can respond inline I will respond here:
- FireFox running on a Windows PC running Windows 10 Pro
- I did do this, I executed the FW upgrade on the RBS's, then RBR.
- After reading some articled online I then remove power from the RBR and RBS's, waited for 1+ minute, restored power to RBR, waited for 1+ minute, then restored power to the RBR's. I still had the connectivity issue for the RBR dropping pings and such.
- AP mode
Static, I assigned an IP address.
I did set to dynamic when I was having the ping/connection issue, thought that I might have a conflict, but no conflict was found on the FiOS GUI, so I went back and set the IP address of the router to
static.
I will try your suggestion about connecting the RBR and the RBS's to my PC, placing the RBR in router mode and then initiating the FW update on the RBR, and go through the power off and wait for sync until. Once complete I will place RBR back in AP mode and connect to FiOS router as you indicated. I will not be able to try this until later this evening or tomorrow morning. In any event, I will share the results.
On another note, should I now see an IOT network? Currently I do not see and IOT network on my RBR.
Thank you for your assistance and suggestions.
