fjsj_168
Jan 29, 2024Tutor
Orbi AX4200 WiFi 6 High-Performance Router (RBR750) -Firmware V7.2.6.21 router issues
Greetings, I am having an issue when upgrading my system from FW version V4.6.14.3_2.3.12 to V7.2.6.21. My configuration is the router is in AP mode, connected to a Verizon FiOS router, and the 2 R...
fjsj_168
Jan 29, 2024Tutor
Thanks for the response FURRYe38,
Since I can respond inline I will respond here:
What browser did you use to apply the FW to the RBR after the RBS were updated?
- FireFox running on a Windows PC running Windows 10 Pro
Did you power OFF the RBR and RBS for 1 minute then back ON to see if the system returned to normal?
- I did do this, I executed the FW upgrade on the RBS's, then RBR.
- After reading some articled online I then remove power from the RBR and RBS's, waited for 1+ minute, restored power to RBR, waited for 1+ minute, then restored power to the RBR's. I still had the connectivity issue for the RBR dropping pings and such.
How is the RBR configured for AP mode?
- AP mode
Dynamic or Static AP configuration?
Static, I assigned an IP address.
I did set to dynamic when I was having the ping/connection issue, thought that I might have a conflict, but no conflict was found on the FiOS GUI, so I went back and set the IP address of the router to
static.
I will try your suggestion about connecting the RBR and the RBS's to my PC, placing the RBR in router mode and then initiating the FW update on the RBR, and go through the power off and wait for sync until. Once complete I will place RBR back in AP mode and connect to FiOS router as you indicated. I will not be able to try this until later this evening or tomorrow morning. In any event, I will share the results.
On another note, should I now see an IOT network? Currently I do not see and IOT network on my RBR.
Thank you for your assistance and suggestions.
Jan 29, 2024Guru - Experienced User
If after updating FW and back in to AP mode you see this connectivity issue, I would probably go for a full on factory reset that maybe needed here:
- AP mode
static.
Where are you setting the Static IP address? On the Verizon router or on the RBR in AP mode itself?
What is the Static IP address your using?
Please review the attached Static AP mode configuration process. I use this when I put mine into AP mode.
I made a good detailed Manual FW update process document here:
After getting v7 loaded on the RBR, the separate IoT network will be available for use:
- fjsj_168Jan 30, 2024Tutor
Just a quick update, I was unable to complete the actions listed above as I was unable to bring down the network due to work deadline. Will attempt to complete this task this evening.
Apologies, forgot to add this information that was requested. I am setting the static IP on the RBR itself and the IP address that I am using is 192.168.1.110. Thanks again for all the great information that you supplied and let me know your thoughts if it is better to define the IP on the RBR or define on the VZ FiOS router.
- FURRYe38Jan 30, 2024Guru - Experienced User
I would change the default DHCP IP address pool on the Verizon router to 192.168.1.100 to .200. Then set a static IP address for the RBR750 in AP mode to 192.168.1.75.
Any static IP addressed devices have to reside outside of a host routers DHCP IP address pool range, not with in it.
