Yank24
Aug 10, 2023Aspirant
Orbi AX4200 WiFi 6 High-Performance Router (RBR753) lost satellite
I have the AX4200 with 3 units. Had been working fine but after an ISP issue the other day one of the satellites simply won't sync. Main router is connected directly to my Xfinity modem (in bridg...
- Aug 10, 2023
Turn OFF the working RBS.
Bring the non working RBS to same room as RBR and wirelessly since it first to the RBR. Once it's fully synced, while in same room ethernet connect the RBS to the back of the RBR. Check to see that it syncs fully via ethernet. Give about 5 minutes. Check the RBR web page and Orbi app.
Try the working RBS at the ethernet RBS location.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.Is there a LAN switch in between the RBS and RBR or LAN cable patch panel?
Aug 10, 2023Guru - Experienced User
- Yank24Aug 10, 2023Aspirant
Thanks for the suggestions. Will try them tonight when my wife is not going to freak out about the network being down for a little bit 🙂
Oh, also... I have two switches but none between the RBR and the RBS. The RBS was wired directly to the RBR. There's a switch connected to the RBR as well, and that relays to my smart hub devices (hue, lutron, etc). And the working RBS also has a switch connected to it for the PS5 and a few other devices in my media room.
- FURRYe38Aug 10, 2023Guru - Experienced User
- Yank24Aug 11, 2023Aspirant
Haven't had a chance to test yet, but have somewhat related questions.
I assume that if the RBS is on a wired connection, any devices that connect via wired to that RBS (via direct or via switch) will experience wired connection speeds. Is that true?
Is there actually a benefit for any devices to be wired to an RBS (via direct or via switch) if that RBS is wirelessly connected to the RBR? The RBS in my media room is just a few feet away from my console and streaming boxes, so not sure if the wiring them to a wireless access point makes any difference.
- Yank24Aug 15, 2023Aspirant
Appreciate the tips, but I think I'm ultimately going to just do a full factory reset on all of them. Last time I tried to fix an edge issue I ended up taking the network down and then having to do the factory reset anyway. #FingersCrossed
- FURRYe38Aug 15, 2023Guru - Experienced User
Let us know how it turns out.
