Yank24
Aug 10, 2023Aspirant
Orbi AX4200 WiFi 6 High-Performance Router (RBR753) lost satellite
I have the AX4200 with 3 units. Had been working fine but after an ISP issue the other day one of the satellites simply won't sync. Main router is connected directly to my Xfinity modem (in bridg...
- Aug 10, 2023
Turn OFF the working RBS.
Bring the non working RBS to same room as RBR and wirelessly since it first to the RBR. Once it's fully synced, while in same room ethernet connect the RBS to the back of the RBR. Check to see that it syncs fully via ethernet. Give about 5 minutes. Check the RBR web page and Orbi app.
Try the working RBS at the ethernet RBS location.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.Is there a LAN switch in between the RBS and RBR or LAN cable patch panel?
Yank24
Aug 15, 2023Aspirant
Appreciate the tips, but I think I'm ultimately going to just do a full factory reset on all of them. Last time I tried to fix an edge issue I ended up taking the network down and then having to do the factory reset anyway. #FingersCrossed
Aug 15, 2023Guru - Experienced User
Let us know how it turns out.
