Keemostrauby's avatar
Keemostrauby
Follower
Nov 06, 2023
Orbi AX6000 RBR850
I have recently added T-Mobile 5G Internet to my property.  Can the Orbi AX6000 be set up with that equipment?
  • CrimpOn's avatar
    CrimpOn
    If this is the device that T-Mobile delivered, then the RBR850 system should simply "plug in".
    https://www.t-mobile.com/home-internet/gateway
    The T-Mobile description makes it pretty clear that their intention is for customers to add Google WiFi units to create a mesh.  Using the T-Mobile device to provide internet to a separate mesh WiFi system  has several obvious issues:
    • You would want to disable the WiFi6 4x4 WiFi so that it does not interfere with your own mesh system.
    • Having two routers in the home network creates potential problems for specific applications, typically
      • Some types of internet gaming
      • Allowing access to resources on your network from the internet
      • Allowing VPN access to your network from the internet
      • (internet search for Double NAT will provide more information.)
    • If two routers impact actual usage, then there are a number of solutions:
      • The easiest is to place the T-Mobile device into "Bridge" or "Passthrough" mode so that it performs no router functions.
      • Another solution is to define the IP address of the Orbi router as part of the T-Mobile router's DMZ.
      • Another solution is to put the Orbi router into Access Point (AP) mode, which allows the T-Moblle router to manage the entire network.
    • These issues depend on how much control the T-Mobile "app" gives customers over their device.
    If T-Mobile has a customer community forum, my guess is this topic will have been discussed many times.
  • FURRYe38's avatar
    Something to ask that ISP about.
    Something to keep in mind as well:
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
    https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
