Paul_Mc
May 20, 2025Aspirant
Orbi AXE11000 RBRE960 firmware issue with Synology NAS
 I just noticed that my ORBI 960 is no longer allowing access to my Synology DS 220 NAS.  It seems like this behavior started around February or March of 25.  I have automation on my PC that backs up ...
Paul_Mc
yes, you are correct. I will see if I have a long enough ethernet cable to connect directly to the Orbi from the PC.
- FURRYe38May 20, 2025Guru - Experienced UserPaul_Mc wrote: yes, you are correct. I will see if I have a long enough ethernet cable to connect directly to the Orbi from the PC. What FW Version had the system been on prior to FEB/March?
