shotah
May 11, 2021Follower
Orbi CBR750 & TunnelBroker IPv6 Setup
How to configure IPv6 using tunnelbroker.net? https://tunnelbroker.net/ I can get it to work with other routers such as llinksys and eero, but I cannot get it to work with Orbi CBR750. I look...
May 11, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
shotah wrote:How to configure IPv6 using tunnelbroker.net? https://tunnelbroker.net/
I looked at https://community.netgear.com/t5/General-WiFi-Routers-Non/How-to-configure-IPv6-using-tunnelbroker-net/td-p/488450, but I do not see an option to enable 6to4 tunnel at http://192.168.1.1.
Please let me know if 6 to 4 tunnel is supported on CBR750. If so, how can I enable it?
