Manic451
Oct 29, 2022Aspirant
Orbi CBR750 internet dropping
I have been battling with my orbi dropping the internet connection multiple times a day. It is a CBR750, no satellites. ISP has tested connection up to it multiple times with no issues. Firmware ve...
Manic451
Update:
I attempted to get a log, I am now unable to login to the orbi. Every time I enter the username and password, it tells me to reset the password…
As I mentioned in the original post, all lined up to the orbi have been tested and confirmed good by the ISP.
Oct 30, 2022Guru - Experienced User
Be sure to clear out all browser caches before entering the modems web page.
Try a different browser to log in.
Will need to review the cable connections and event logs pages here.
- Manic451Oct 30, 2022Aspirant
Please see below:
Startup Procedure Procedure Status Comment Acquire Downstream Channel 525000000 Hz Locked Connectivity State Ok Operational Boot State Ok Operational Security Enabled BPI+ IP Provisioning Mode IPv6 Only ipv6Only(1) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectable 1 Locked QAM 256 32 519000000 Hz 8.1 dBmV 40.3 dB 10 0 2 Locked QAM 256 2 525000000 Hz 8.3 dBmV 40.3 dB 0 0 3 Locked QAM 256 3 531000000 Hz 8.3 dBmV 40.3 dB 0 0 4 Locked QAM 256 4 537000000 Hz 8.1 dBmV 40.3 dB 0 0 5 Locked QAM 256 5 543000000 Hz 8.0 dBmV 40.3 dB 0 0 6 Locked QAM 256 6 549000000 Hz 8.0 dBmV 40.9 dB 0 0 7 Locked QAM 256 7 555000000 Hz 8.0 dBmV 40.3 dB 0 0 8 Locked QAM 256 8 561000000 Hz 8.0 dBmV 40.9 dB 0 0 9 Locked QAM 256 9 567000000 Hz 8.0 dBmV 40.3 dB 0 0 10 Locked QAM 256 10 573000000 Hz 8.0 dBmV 40.3 dB 0 0 11 Locked QAM 256 11 579000000 Hz 7.9 dBmV 40.9 dB 0 0 12 Locked QAM 256 12 585000000 Hz 7.8 dBmV 40.3 dB 0 0 13 Locked QAM 256 13 591000000 Hz 7.6 dBmV 40.3 dB 0 0 14 Locked QAM 256 14 597000000 Hz 7.5 dBmV 40.3 dB 0 0 15 Locked QAM 256 15 603000000 Hz 7.8 dBmV 40.3 dB 0 0 16 Locked QAM 256 16 609000000 Hz 7.6 dBmV 38.9 dB 0 0 17 Locked QAM 256 17 615000000 Hz 7.3 dBmV 38.9 dB 0 0 18 Locked QAM 256 18 621000000 Hz 7.5 dBmV 40.3 dB 0 0 19 Locked QAM 256 19 627000000 Hz 7.0 dBmV 38.9 dB 0 0 20 Locked QAM 256 20 633000000 Hz 7.3 dBmV 38.6 dB 0 0 21 Locked QAM 256 21 639000000 Hz 7.0 dBmV 38.9 dB 0 0 22 Locked QAM 256 22 645000000 Hz 7.0 dBmV 38.9 dB 0 0 23 Locked QAM 256 23 651000000 Hz 7.0 dBmV 38.6 dB 0 0 24 Locked QAM 256 24 657000000 Hz 7.0 dBmV 38.6 dB 0 0 25 Locked QAM 256 26 669000000 Hz 6.6 dBmV 38.6 dB 0 0 26 Locked QAM 256 27 675000000 Hz 6.8 dBmV 38.9 dB 0 0 27 Locked QAM 256 28 681000000 Hz 6.4 dBmV 38.6 dB 0 0 28 Locked QAM 256 29 687000000 Hz 6.4 dBmV 38.9 dB 0 0 29 Locked QAM 256 1 693000000 Hz 6.3 dBmV 38.6 dB 0 0 30 Locked QAM 256 30 699000000 Hz 6.1 dBmV 38.6 dB 0 0 31 Locked QAM 256 31 705000000 Hz 6.3 dBmV 38.9 dB 1 0 32 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Partial Service Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 3 5120 Ksym/sec 30600000 Hz 42.3 dBmV 2 Locked ATDMA 4 5120 Ksym/sec 37000000 Hz 41.5 dBmV 3 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 4 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock Status Modulation/Profile ID Channel ID Frequency Power SNR/MER Active Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 2 33 380000000 Hz 6.8 dBmV 43.6 dB 1108~2987 0 0 0 2 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0~4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation/Profile ID Channel ID Frequency Power 1 Locked 0 1 6025000 Hz 36.5 dBmV 2 Not Locked 0 0 0 Hz 0.0 dBmV
See below for the log:
[Admin login failure] from source 192.168.1.41, Sunday, Oct 30,2022 15:24:31
[DHCP IP: (192.168.1.41)] to MAC address 94:53:30:A3:DB:73, Sunday, Oct 30,2022 15:23:52
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 15:21:52
[DHCP IP: (192.168.1.7)] to MAC address D0:C5:D3:3B:E8:D1, Sunday, Oct 30,2022 15:06:58
[DHCP IP: (192.168.1.35)] to MAC address 26:01:10:48:32:23, Sunday, Oct 30,2022 15:00:53
[DHCP IP: (192.168.1.14)] to MAC address 38:C8:04:FE:A8:8A, Sunday, Oct 30,2022 14:21:09
[DHCP IP: (192.168.1.37)] to MAC address 50:14:79:23:9A:72, Sunday, Oct 30,2022 12:54:54
[DHCP IP: (192.168.1.37)] to MAC address 50:14:79:23:9A:72, Sunday, Oct 30,2022 12:38:53
[DHCP IP: (192.168.1.37)] to MAC address 50:14:79:23:9A:72, Sunday, Oct 30,2022 12:36:12
[DHCP IP: (192.168.1.5)] to MAC address 80:7D:3A:38:AA:60, Sunday, Oct 30,2022 12:14:21
[DHCP IP: (192.168.1.6)] to MAC address 84:F3:EB:3A:7B:A0, Sunday, Oct 30,2022 12:14:03
[DHCP IP: (192.168.1.9)] to MAC address 84:F3:EB:3A:7E:2D, Sunday, Oct 30,2022 12:13:49
[DHCP IP: (192.168.1.10)] to MAC address 2C:F4:32:1D:40:A8, Sunday, Oct 30,2022 12:13:27
[DHCP IP: (192.168.1.11)] to MAC address C4:4F:33:9A:72:57, Sunday, Oct 30,2022 12:13:20
[DHCP IP: (192.168.1.8)] to MAC address 80:7D:3A:63:3B:08, Sunday, Oct 30,2022 12:13:18
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 12:12:30
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 12:10:13
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 12:07:57
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 12:04:45
[DHCP IP: (192.168.1.35)] to MAC address 26:01:10:48:32:23, Sunday, Oct 30,2022 11:12:47
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 11:10:20
[DHCP IP: (192.168.1.23)] to MAC address F8:FF:C2:07:D2:1C, Sunday, Oct 30,2022 10:48:12
[DHCP IP: (192.168.1.36)] to MAC address 82:CF:A5:4E:7B:CE, Sunday, Oct 30,2022 10:32:08
[DHCP IP: (192.168.1.23)] to MAC address F8:FF:C2:07:D2:1C, Sunday, Oct 30,2022 10:30:26
[DHCP IP: (192.168.1.34)] to MAC address 38:9D:92:B2:DF:E9, Sunday, Oct 30,2022 10:29:55
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 10:29:49
[DHCP IP: (192.168.1.21)] to MAC address E0:4F:43:DB:75:BC, Sunday, Oct 30,2022 10:26:33I have not had the internet drop today as of yet.
- FURRYe38Oct 31, 2022Guru - Experienced User
Power levels are too high:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
I would ask the ISP to turn down the power some.
- Manic451Nov 24, 2022Aspirant
I have had the cable company come out to turn down the power. They have done that but no change to the internet connection.
I still have this ongoing- FURRYe38Nov 25, 2022Guru - Experienced User
Please re-post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
