Gangrel's avatar
Gangrel
Follower
Mar 18, 2023
Orbi CBR750 Xfinity speed drop every 3 days
Looking over the forums, it seems a lot of people are having issues with the CBR750 and Xfinity. In my particular case, every 3 days, my connection speed drops to nothing and I have to reboot.
It's been happening since November, but I only started tracking the issue since February. What I've found is this.
I say every 3 days, but on average it's every 2 days and 20 hours this message appears in my event log:
Notice (6) | DS profile config update. DS Chan ID: 193.
Every single time this appears, without fail, I have to restart the modem. It then works nicely for another 2 days 20 hours, and happens again.
I just had an Xfinity engineer here, checking the lines inside and out and finding nothing wrong. However, he told me that Netgear is a topic of discussion within Xfinity. Many of the calls they have been getting are Netgear specific.
He couldn't tell me what this DS profile config update is, or where it's coming from, but thinks it's conflicting with the Netgear firmware. He suggested finding a version of the firmware prior to November, when the problem started, and seeing if I can revert to that. I don't know how to find such a thing, tho, so can't try it.
On rebooting, there is an additional pair of messages that appear in the event log:
Notice | TLV-11 - unrecognized OID
Critical | Config File Rejected due to Invalid or Unexpected TLV 11
This makes me think perhaps a firmware update changed the format of a config file, and perhaps the source of that DS profile config update hasn't take it into account? I don't know, it's speculation.
As FURRYe38 asked, here are my deets.
Firmware Version V4.6.14.4_2.3.12
Speed Tier 200 Mbps
Okay... it seems I can't upload the txt dump of the cable diagnostics. Odd. Here's a copy paste:
Cable Diagnostic
Status:   Good
Action:   Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access: [green]
Downstream Status: [green]
Upstream Status: [green]
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel579000000 HzLocked
Connectivity StateOkOperational
Boot StateOkOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectable
1LockedQAM 2561417000000 Hz3.2 dBmV43.3 dB00
2LockedQAM 2562423000000 Hz3.4 dBmV40.9 dB20
3LockedQAM 2563429000000 Hz3.2 dBmV40.9 dB00
4LockedQAM 2564435000000 Hz3.4 dBmV43.3 dB00
5LockedQAM 2565441000000 Hz3.4 dBmV43.3 dB00
6LockedQAM 2566447000000 Hz3.0 dBmV43.3 dB00
7LockedQAM 2567453000000 Hz3.2 dBmV40.9 dB00
8LockedQAM 2568459000000 Hz3.4 dBmV43.3 dB00
9LockedQAM 2569465000000 Hz3.5 dBmV40.9 dB00
10LockedQAM 25610471000000 Hz3.4 dBmV40.9 dB00
11LockedQAM 25611477000000 Hz3.4 dBmV40.9 dB00
12LockedQAM 25612483000000 Hz3.2 dBmV40.9 dB00
13LockedQAM 25613489000000 Hz3.4 dBmV40.9 dB00
14LockedQAM 25614495000000 Hz3.4 dBmV40.9 dB00
15LockedQAM 25615501000000 Hz3.2 dBmV40.9 dB00
16LockedQAM 25616507000000 Hz3.4 dBmV40.9 dB00
17LockedQAM 25617513000000 Hz3.7 dBmV40.9 dB00
18LockedQAM 25618519000000 Hz3.7 dBmV40.9 dB00
19LockedQAM 25619525000000 Hz3.7 dBmV40.9 dB30
20LockedQAM 25620531000000 Hz3.9 dBmV40.9 dB00
21LockedQAM 25621537000000 Hz4.0 dBmV40.9 dB00
22LockedQAM 25622543000000 Hz4.3 dBmV40.9 dB00
23LockedQAM 25623549000000 Hz4.5 dBmV40.9 dB00
24LockedQAM 25624555000000 Hz4.5 dBmV40.9 dB00
25LockedQAM 25625561000000 Hz4.6 dBmV40.9 dB00
26LockedQAM 25626567000000 Hz4.6 dBmV40.9 dB00
27LockedQAM 25627573000000 Hz4.6 dBmV40.9 dB00
28LockedQAM 25628579000000 Hz4.6 dBmV40.9 dB00
29LockedQAM 25629585000000 Hz4.8 dBmV40.9 dB00
30LockedQAM 25630591000000 Hz4.8 dBmV40.9 dB00
31LockedQAM 25631597000000 Hz5.0 dBmV40.9 dB00
32LockedQAM 25632603000000 Hz5.5 dBmV40.9 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec16400000 Hz48.0 dBmV
2LockedATDMA25120 Ksym/sec22800000 Hz48.3 dBmV
3LockedATDMA35120 Ksym/sec29200000 Hz48.5 dBmV
4LockedATDMA45120 Ksym/sec35600000 Hz48.5 dBmV
5Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
6Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
7Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
8Not LockedN/AUnknown0 Ksym/sec0 Hz0.0 dBmV
Downstream OFDM Channels
ChannelLock StatusModulation/Profile IDChannel IDFrequencyPowerSNR/MERActive Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked3193957000000 Hz5.5 dBmV42.1 dB148~3947000
2Not Locked000 Hz0.0 dBmV0.0 dB0~4095000
Upstream OFDMA Channels
1Not Locked000 Hz0.0 dBmV
Current System Time: Sat Mar 18 13:41:08 2023
System Up Time 01:56:33
Unfortunately I can't share my event log. I'm getting an error in the browser console, trying to view the event log:
  • FURRYe38's avatar
    What speed package do you pay for from the ISP up and down? 800Mbps or 1.2Gb?
    What browser are you using? Does this happen in a different browser when you try to collect the event logs?
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
    Press the back reset button for 15 seconds then release.
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
    Most Critical, Errors or Warnings  seen in the Event Log needs to be reviewed by the ISP and resolved.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello Gangrel ,
    Welcome to the NETGEAR Community!
    I understand that you are experiencing network connection issues with your CBR750.
    Please provide the following information so I can endorse you to our experts to further analyze this issue:
    Name:
    Email:
    Phone Number:
    Device Model:
    Firmware:
    Serial Number:
    Preferred time to be contacted:
    App version:
    Please provide this information as soon as possible!
    I look forward to hearing from you!
    Best,
    Kevin
    Community Team
