Dewiz_45's avatar
Feb 23, 2023
Orbi disconnects iPhones only
I had purchased the Orbi RBR750 a few years ago because Netgear was having a sale on them . I had an Orbi RBR50 before this that ran flawlessly, 0 issues which I ended up giving to my brother so when we started having these issues with the RBR759, it really baffled me because I never experienced these issues with the RBR50.
Now this doesn’t happen every day but like once every 1-3 months and when it does happen, my wife’s and I iPhones will be affected for 2-3 days & then it’ll go back to normal like nothing happened for another 1-3 months until it comes back. I can’t connect to my WiFi but when it does show the WiFi symbol at the top right of my iPhone for example I’m getting like 0.01 MPBS & nothing will load on Google Chrome, YouTube, twitter, Facebook, etc. Earlier today I was watching YouTube and it was running perfect & then bam it stopped playing ,started buffering and I got no WiFi signal. It’s 2 hours later and still won’t connect to WiFi
Now we have 2 AppleTV’s, Ring Pro doorbell, 3 tablets, two Roku sticks, Roku TV and none of these devices are affected by this. It’s just our damn iPhones lol. My wife has the iPhone 12 Pro Max & I have the iPhone 13 Pro Max & both phones are updated to the currently firmware.
Last time this happened, there was a firmware update on the Orbi which seemed to have fixed it that time. Now that’s it’s affecting me right at this instant, I’ve checked the Orbi for an update and my firmware is up to date which is version V.4.6.14.3. I’ve done every troubleshooting I could google for my iPhone such as turning WiFi off & back on, forgetting WiFi, reset Network settings, restarting my iPhone etc. with zero fix.
Any help would be greatly appreciated because I hate dealing with this issue every 1-3 months that will last a few days.
  • plemans's avatar
    Have you disabled the iphones random mac/ip address feature? Plus disable icloud relay?
    That's where I'd start with them.
    • Dewiz_45's avatar
      Dewiz_45
      Tutor
      I disabled the private wifi address but the iCloud private relay was already turned off. Let’s see if this fixes it
    • Dewiz_45's avatar
      Dewiz_45
      Tutor
      Was working last night but not this morning having the same issues, hooked up to my WiFi with no internet . Back to square one
      • plemans's avatar
        What modem/gateway is the router connected to?
        What firmware version is on the router and the satellites?
        Are you using IPv6?
        Any parental controls or access controls being used?
  • FURRYe38's avatar
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    How many RBS are deployed?
    Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    • Dewiz_45's avatar
      Dewiz_45
      Tutor
      I did everything you told me to do, rebooted the router & reconnected my satellites once the router was done rebooting.
      As for my neighbors WiFi only 3 show up
      My square footage for my house is just shy of 3,000 and I have 1 satellite downstairs with my router and 2 upstairs. I
      • FURRYe38's avatar
        Also try turning down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
