StratNetworker's avatar
Jun 09, 2020
Orbi firmware update blocks https
Just updated to firmware V3.2.15.25_1.3.15 last night, and now I can't just type https://192.168.1.xxx to access my NAS. The laptop is wired and the NAS is wired, but the Orbi is my DHCP router.
Any thoughts why?
Thanks!!!
  • CrimpOn's avatar
    CrimpOn
    V3.2.15.25_1.3.15 is not a firmware release for the Orbi RBR50.  What exactly was updated?
    Is the NAS the only device that does not accept https?
  • FURRYe38's avatar
    Check the IP address of the NAS on the RBR. IP addess may have changed.
    Reboot the NAS.
    • Chuck_M's avatar
      Chuck_M
      Mentor
      What is brand name/model of NAS?
      Is that NAS set to a static IP?  If not, you might want to consider that.
      Most NAS' also require a specific port forwarded... are you putting that port into the IP address?  (e.g. 192.168.1.14:5000)
      • schumaku's avatar
        schumaku
        We're in the 21st century, and e.g. Windows 10 can easily use the WS-Discovery based name resolution (and even NetBIOS name resolution if enabled for legacy NAS systems) to find the NAS based on it's name on the network, so eg. https://nasname/ does the job.
        Alternate, or in addition, the OP might consider adding an Address Reservation so the same NAS interface does get (based on it's MAC address) the same IP address assigned from the Orbi AX router.
        Port forwarding is only required for access from the Internet/WAN side.
  • FURRYe38's avatar
    Any progress on this?
    Does HTTP vs HTTPS and IP address of NAT work?
    As suggested, make sre the NAS is using a static IP address set ON the NAS or you can set a IP address reservation for the NAS ON the router. I use static IP addresses on my two NAS so the know the IP address doesn't change. HTTP works fine for my needs.
    Disable any amror features temporarily to check this.
    Any thoughts why?
    Thanks!!!
