LeslieF
Oct 29, 2022Aspirant
Orbi guest network RBR850 does not turn off
I turned on the guest network once when I had visitors and I thought I turned it off. Now when I go in the settings, guest network is NOT enabled, but I still see the guest network when I look at th...
Oct 31, 2022Guru - Experienced User
After you disabled the GN on the RBRs web page and applied the change, did you do a reboot of the RBR?
