Maxi_orbi
Apr 15, 2024Aspirant
orbi has issues (model : RBR850 , serial number:687A1C7EA0C82
My orbi has an issue; in fact, I can't locate it on my orbi app, and the router doesn't connect to the internet. Model: RBR850, serial number: 687A1C7EA0C82, and I can't log in to it. I really don't know what else to do about it.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Any front LED indications?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageHas a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2356834/highlight/true#M52575Please avoid putting serial numbers or MAC addresses in public forums.
- Maxi_orbiAspirant
The firmware or version that is currently loaded is version: 2.35.0.336
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?The product number (PN) of the internet provider (starlink) is :34600000-510/C
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.I’m using the LAN cable that came with the orbi router CAT.5E
Yes, it turns on LED indicator
- Maxi_orbiAspirant
MODEL: UTR-211
