Mo3lim's avatar
Mo3lim
Orbi Internet connection issue
My Orbi RK852 router lost internet connection constantly for 5 sec 4 to 5 times a day after update to latest firmware V4.6.7.13_2.1.9
Which is really irritating now I am thinking to downgrade to previous stable version before I do so any suggested soulutions will be highly appreciated
Does anyone facing the same issue ?
  • FURRYe38's avatar
    How was the system updated? Autoupdate or by manual FW update?
    Did you power cycle the ISP modem or ONT and RBR OFF for 1 minute or longer then back ON after the FW was updated?
    • Mo3lim's avatar
      Mo3lim
      First of all, thanks for your support and trying to help .
      For your questions, the firmware has been manually upgraded through the web page
      I have tried all the solutions you suggested but unfortunately the issue still exists
      The ONT is connected to the service Huawei EchoLife EG8040H5 modem
      • FURRYe38's avatar
        Try a factory reset on the Orbi system and setup up from scratch. Power off the ONT for 1 minute then back ON. Complete the setup of the Orbi system.
