Dustin_V
Jan 09, 2019NETGEAR Employee Retired
Orbi Mesh Wi-Fi with Wi-Fi 6 For The Gigabit Internet Home - #NETGEARCES2019
Orbi Whole Home WiFi just got even faster! NETGEAR is continuing to lead the new era of Wi-Fi. To kick off CES 2019, we announced plans to pair award-winning Orbi Wi-Fi with the latest Wi-Fi s...
mranjan78
Jan 10, 2019Initiate
Is it possible to upgrade the existing orbi RBK50 wifi systems which I already have? OR I just have throw away the existing systems and buy the new model with wifi 6 standard?
- tagteamJan 10, 2019Virtuoso
The hardware is different so you will have to buy the new model if you want Wi-Fi 6.
- Ragar99Jan 10, 2019Luminary
Jeeze, we will probably never see another firmware update for the current Orbi once this comes out.
On the bright side, it will be another forum the Furry and EK bots can post to!
- FURRYe38Jan 11, 2019Guru - Experienced User
Of course. I am to please. :smileyvery-happy:
Enjoy.
- randomousityJan 12, 2019Luminary
Wifi 6 will have different radio hardware, so there won't be any way to upgrade existing devices to Wifi 6 unless you can swap out components, like on a desktop, or a USB dongle for a laptop. But anything with an integrated radio (laptops, phones, tablets, probably nearly all "smart" devices) will just be capped at whatever level it left the factory with. A Wifi 4 device can only work at Wifi 4 levels, even on a Wifi 5 router. You can still use it with a Wifi 5 or Wifi 6 router, but you won't get all the benefits of Wifi 6 unless both the router and the device are Wifi 6.
(Assuming Netgear gets the firmware fixed on the current models) just keep using them until they fail or are insufficient to meet your needs. Factory reset it and sell it used if you really feel the need to upgrade before hardware failure or end of support from Netgear. There aren't even any consumer devices with Wifi 6 hardware yet, so even if you upgraded to the latest and greatet Orbi, you won't have any devices able to take full advantage of it. Even once they hit the market, it'll depend where you are in your upgrade cycle for phones, laptops, consoles, etc., anyway. If all your devices are Wifi 5 (or lower), there's simply no need to get a Wifi 6 router unless you already need a new router anyway. IMO, the bare minimum requirement to elect to upgrade your router to Wifi 6 (as opposed to a mandatory replacement due to failure) is that you have at least one device with Wifi 6, you are maxing out the Wifi 5 with that device, and you would actually benefit from upgrading the router to Wifi 6. Anything less than meeting all three of those conditions is just throwing money away to have the latest and greatest for the sake of having it now. You'd be better off deferring the purchase for six or twelve months and getting the same Wifi 6 router for less when the price comes down. Or even a better one for the same price. Either way, a better value.
I used my old cable modem for over a decade, and only upgraded it when I got bumped up to a plan that was faster than my old modem could handle. I've only replaced routers when the old one either failed or didn't cover as large an area as I needed.
- raven_auJan 14, 2019Virtuoso
Clearly the new wireless will be different.
But the AX chipset should be able to provide AC support as well.
So the question becomes can AC based Oribi devices be used with the new AX based Orbi devices.
For example, if one gets a Router plus Satelite AX based pack can AC based satelites that customers already have be used with the new AX based Orbi router?
- randomousityJan 15, 2019Luminary
I assume they'll make the new Orbis backwards-compatible, so that a new Wifi 6 router will work with an old Wifi 5 satellite, or a new Wifi 6 satellite will work with an old Wifi 5 router.
