kenchiu
May 10, 2021Aspirant
Orbi Mesh WiFi 6 System with Built-in DOCSIS 3.1 Cable Modem - AX4200 (CBK752) Connection drop
Hi, I purchased the Ax4200 3 months ago. Over the last 2 months, I have been experiencing unstable connection (frozen screen, lost connection) in my Google Meet and Zoom meeting. My macbook was c...
May 10, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
kenchiu
Thanks for the reply. Plesae see my answers below. I also have two questions.
a) My Macbook Pro is placed very close to RBS750 Orbi Satellite, but the Orbi app doesn't show the full wifi strength (2 ooy if 3 bars)
b) Where can I check the connection log of my Orbi router and Orbi Satellite
c) Do you see any issues if the distance between Orbi router and Orbi Satellite is less than 30 feets? the separation is about 29 feet.
My answers to your questions
1) CBR750 - V3.2.18.2; RBS750 - V3.2.18.1
2) 1800 sq feet. The Orbirouter and Orbi satellite are on the same floor. but there are two walls between them
3) 2.4 Ghz channel - 11; 5Ghz channel - 48
4) About 4 wifi neighbors
5) Armor - not activiated
