kenchiu
May 10, 2021Aspirant
Orbi Mesh WiFi 6 System with Built-in DOCSIS 3.1 Cable Modem - AX4200 (CBK752) Connection drop
Hi, I purchased the Ax4200 3 months ago. Over the last 2 months, I have been experiencing unstable connection (frozen screen, lost connection) in my Google Meet and Zoom meeting. My macbook was c...
May 10, 2021Guru - Experienced User
do you have issues with wired device? Or just wireless?
Its also worth checking the cable connection if you're having issues with wired devices as well.
Got a screen snip of the cable connections page and the modem event logs from the cbk752?
- kenchiuMay 10, 2021Aspirant
The issue is only with wireless device.
- FURRYe38May 11, 2021Guru - Experienced User
Disable the following: IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Does both Zoom app and browser based Zoom see this problem?
- kenchiuMay 11, 2021Aspirant
For zoom, the issue happened with zoon app
For google meet, the issue happened with chrome browser
Do you know what caused the connection drop issue? interference?
