kenchiu
May 10, 2021Aspirant
Orbi Mesh WiFi 6 System with Built-in DOCSIS 3.1 Cable Modem - AX4200 (CBK752) Connection drop
Hi, I purchased the Ax4200 3 months ago. Over the last 2 months, I have been experiencing unstable connection (frozen screen, lost connection) in my Google Meet and Zoom meeting. My macbook was c...
May 10, 2021Guru - Experienced User
do you have issues with wired device? Or just wireless?
Its also worth checking the cable connection if you're having issues with wired devices as well.
Got a screen snip of the cable connections page and the modem event logs from the cbk752?
kenchiu
The issue is only with wireless device.
- FURRYe38May 11, 2021Guru - Experienced User
Disable the following: IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Does both Zoom app and browser based Zoom see this problem?
- kenchiuMay 11, 2021Aspirant
For zoom, the issue happened with zoon app
For google meet, the issue happened with chrome browser
Do you know what caused the connection drop issue? interference?
Possible. You can ethernet connect your Mac to the CBR or RBS and see if this changes anything.
