zb411
Sep 03, 2023Follower
Orbi Network Disconnects from Phone
Hello I have an RBR850 system and when walking around my home my phone consistently disconnects from the network and often will take a long time to reconnect even if the network shows up in the wifi s...
michaelkenward
Sep 04, 2023Guru - Experienced User
zb411 wrote:
Hello I have an RBR850 system and when walking around my home my phone consistently disconnects from the network and often will take a long time to reconnect even if the network shows up in the wifi settings as having strong signal.
Is it just this phone that loses the connection? What about other phones? You need to rule out the phone as the cause of the problem.
What is this phone? An iThing?
.iNETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
You might like to search there for messages related to your problem.
