  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
    • Boldlygoborg's avatar
      Boldlygoborg
      To add clarity it was working fine before yesterday morning. A storm rolled through and we lost internet (never lost power).
      The modem is A nighthawk CM2000.
      Have already tried the power cycling steps several times without fixing it.
      • FURRYe38's avatar
        Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended between the RBR and CM modem.
        Do does a wired PC connected to the CM modem with out the RBR connected to the modem work or does the PC not get internet here as well? Connect 1 wired PC to the modem and power the modem OFF for 30 seconds then back ON. Check for internet services with the PC.
