ysvsr1's avatar
ysvsr1
Orbi R750 not able to find daisy chain option under advanced wireless settings
I am not able to find Daisy chain or MIMU or implicit beam forming etc options under
Orbi Settings > Advanced > Advanced Setup > Wireless Settings.
Firmware Version V3.2.16.6_1.4.4
I am not getting better speed with this router and trying to find solution to improve wifi. Thanks in advance.
  • FURRYe38's avatar
    Those options are not available on Orbi AX. Those are being handled automatically. So placement will be key if you want to use Daisy Chain or have a Start formation with the RBS from the RBR.
    What speeds are you expecting with Orbi AX?
    What devices are you using with Orbi AX?
    • ysvsr1's avatar
      ysvsr1
      I am getting 150 mb download speed from my provider. I am expecting at least 75mb speeds. With my old rbr50 model, I am getting around 35-40 mb. Main issue is lot of variation in speeds in consecutive sppedtest tests. One time, I get above 70 and next I get 30-40. Same place same device, so I dont know whether this upgrade model is really useful to me or not. We have plenty of wifi devices like ring alarm, door bello, phones, ipads and laptops. Apple tv and tivo are hard wired to satellites. My internet provider modem/router wifi is turned off and using orbi in router mode.
      our house is 3 stories including basement. Main router and orbi are in first floor libing room. One satellite is. Master bedroom above the living room on the opposite site. Second satellite is in basement on the opposite side of main router. I hope this information will give more clarity to you. Thanks for your kind support.
