Smurf_paul's avatar
Smurf_paul
Orbi RB850 Wifi connected devices get diffrent ip subdomain plex
Ok so I have an interesting problem. The current setup, 2 satelights and the base. The base is in Router mode, connected to a fiber modem/router.
The base is connected to a network switch.
The Base is set to use the 192. 168 . 0  range wifi is on .
The modem is set to use the 192.168 1 range (only device is the base), wifi is off.
Everything connected to the switch, or wired to the base or satelights works perfectly. We have a plex server running, wired to the swicth. Every device can connect and its setup so remote can access the server.
Now every wifi device, connects, to the orbi system, but it gets a ip on the modem ip range, and thus cant see the other devices, as they are on a diffrent sub net.  Cant work out why wifi devices get ip from modem, and wired get ip from orbi, when the only wifi is the orbi?
  • FURRYe38's avatar
    This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Option #1 is preferred.
    • Smurf_paul's avatar
      Smurf_paul
      The router cant be bridged :( ALL the radios are off on the router,  the exposed host is set to the base orbi, along with a static ip.
      Everything wired works, perfectly, but any wifi device that wants to talk to a wired connection, goes via the internet port ip.
      Which means things like plex, every wifi device it see's as a remote device rather than a local one, but only for the wifi devices connected to the orbi system.
      The only connection to the router, is the network cable to the orbi. Everything else is on the orbi side.
      • FURRYe38's avatar
        That seems odd, if ALL wifi on the modem is OFF fully, and you set up the DMZ or IP passthru on the modem for the RBR. ALL wifi devices connected to the RBR or RBS should be getting a 192.168.1.something address from the RBR and communicating on the RBR side of the network.
        Is uPnP disabled on the modem?
        I would try this to help narrow this down. Remove the DMZ configuration on the ISP modem and configure the RBR for AP mode. This will set the modem and main host router only and everything will get an IP address from the modem however wired and wireless should connect on the one modem network.
