Patrick1506
Oct 22, 2023Follower
Orbi RBE960 with 4 Satellites
Good evening all, I intend to buy an ORBI RBE 960 with 3 satellites in order to cover the entire house (4000 Sq ft). I just have one question: do the satellites connect to each other wireless as...
CrimpOn
Oct 22, 2023Guru - Experienced User
AS long as the distance of each "hop" provides a strong signal, yes it should work.
But there may be issues with performance. Netgear recommends a maximum of two satellites in a Daisy Chain:
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
