Patrick1506
Oct 22, 2023Follower
Orbi RBE960 with 4 Satellites
Good evening all, I intend to buy an ORBI RBE 960 with 3 satellites in order to cover the entire house (4000 Sq ft). I just have one question: do the satellites connect to each other wireless as...
Oct 22, 2023Guru - Experienced User
For that size of home, depending on building materials, the router unit and just two sateliites should be sufficient. I have a 5000sq ft home 3 levels and can get by with just one ethernet connected sattellie. When I have two satellites running, I turn the power down to 25%.
30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Patrick1506 wrote:
Good evening all,
I just have one question: do the satellites connect to each other wireless as the distance from the router to all satellites would be too far to get a correct connection.
Router to Satellite 1 then Satellite 2 to Satellite 1 and then Satellite 3 to satellite 2, this all in wireless.
Thank you very much
