WCJ47's avatar
WCJ47
Orbi RBK 350 connected to BT Smart Hub 2
Hi
I'm having intermittent problems with an Orbi 350 linked to a BT Smart Hub 2.
My internet is provided via BT Fibre 2 with a Smart Hub 2.
The Smart Hub 2 is hard wired to an Orbi RBK350 with two satellites.
The Orbi was set up out of the box and worked OK – then occasionally the link between the Hub 2 and the RBK350 would drop.
Searching the internet for solutions I read the RBK350 should be set up as AP Mode. I have made this change but still experience the problem of the Orbi not connecting to the Hub 2 intermittently.
I can monitor the Orbi network on a tablet and can see the link drop between the Hub 2 and RBK350 on the Network Map, after a while the link then re-establish it's self without any intervention and our PC and TV can then access the internet.
The Orbi RBK350 is on the latest version of firmware software :- v4.1.29_3.10.80
Has anybody got suggestion how the Orbi should be configured to solve this problem???
Thanks
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try Option #2 first.
    Might ask the ISP if the Smart Hub can be replaced by the RBR.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    • WCJ47's avatar
      WCJ47
      Hi Furrye38
      Opt 1 Contacted ISP they are unable to change configuration on hub.
      Opt 2 Managed to disable all WiFi on hub but can't change the hub configuration used Orbi in Router mode - problem still occurs.
      Opt 3 Managed to disable all WiFi and Orbi configured AP mode - problem still occurs.
      I'm willing to replace hub for a RBR but don't know what a RBR is can you please explain.(network beginner).
      House has 4 bedroom two stories and satellites work fine when the link is established.
      Thanks for your help
      WCJ47
