HansWest's avatar
HansWest
Orbi rbk 852 Sennheiser Ambio soundbar
The Sennheiser Ambeo Soundbar does not want to connect WiFi to the Oribi router rbk852
  • plemans's avatar
    what modem/gateway do you have?
    What actually happens?
    What error do you get?
    What firmware is on the router?
    Details are key in helping out.
    • HansWest's avatar
      HansWest
      my router is an orbi rbk 852 which i can't choose in the menu of this forum. My Sennheiser Ambio Soundbar will not connect to WiFi orbi rbk 852. If I try my old modem, it works without any problems. When I try WDS the Soundbar keeps searching for the WiFi but does not connect. If I enter the data manually, no connection is established. orbi is on latest firmware V4.6.3.16 Soundbar also latest firmware 1.0.153 both not the cheapest but does not work as it should.
