challs
Aug 22, 2025Guide
Orbi RBK 852 Wi-Fi Drop Issue (RBR850/RBS850)
Hi all, I'm having ongoing issues with my brand new Orbi AX6000 (RBK852) system. My place is actually less than half the size of the coverage sq footage (2200 sq ft). But my modem is upstairs and...
Aug 22, 2025Guru - Experienced User
30 feet distance is starting between the RBR and the RBS. 20 feet would be too close between the RBR and RBS.
Try channel 1 and 40 or 11 and 48.
Is IPv6 enabled on the RBR? IF it is, disable it.
Enable SIP ALG on the RBRs web page under Advanced Tab/Setup/WAN Setup.
