challs
Aug 22, 2025Guide
Orbi RBK 852 Wi-Fi Drop Issue (RBR850/RBS850)
Hi all, I'm having ongoing issues with my brand new Orbi AX6000 (RBK852) system. My place is actually less than half the size of the coverage sq footage (2200 sq ft). But my modem is upstairs and...
Aug 22, 2025Guru - Experienced User
30 feet distance is starting between the RBR and the RBS. 20 feet would be too close between the RBR and RBS.
Try channel 1 and 40 or 11 and 48.
Is IPv6 enabled on the RBR? IF it is, disable it.
Enable SIP ALG on the RBRs web page under Advanced Tab/Setup/WAN Setup.
challs
Aug 22, 2025Guide
Changed channels.
IPv6 already disabled.
Tried enabling SIP ALG ... I just unchecked the Disable SIP ALG button.
I didn't move the Satellite yet, pending your response below.
- FURRYe38Aug 23, 2025Guru - Experienced User
Does problem happen if you turn OFF the RBS and just run with the RBR?
- challsAug 24, 2025Guide
Yes, I tried this and it still runs into the same issue.
- FURRYe38Aug 25, 2025Guru - Experienced User
With all RBS online, you could downgrade the FW on the RBS first to v.21 then downgrade the RBR lastly.
After the RBS and RBR are downgraded, you'll need to factory reset the system and setup from scratch, then see if problem resolves or not.
