Gaspi
Dec 13, 2020Follower
Orbi RBK 853 - Router fron led alwasy withe
Hi All
Since 2 days I have an Orbi RBK 853.
I setup Router and Satelite and it works fine actually!
One thing I can not understand ist the the Router RBK850 connected via Lan cable to the Internet Modem works perfectly but the front led is always wite, no blinking just wite.
Is this normal? should I do something else? Usually sould swiss off if everithning is fine isn't it?
Thanks for you adwise
Regards Gaspare
Gaspi wrote:One thing I can not understand ist the the Router RBK850 connected via Lan cable to the Internet Modem works perfectly but the front led is always wite, no blinking just wite.
Is this normal? should I do something else? Usually sould switch off if everithning is fine isn't it?
Yes, page 10 of the User Manual states that "solid white" means "The router is resetting to its factory default settings". The front LED is supposed to be off during normal operations. Something is not right. User Manual is here:
https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
There is a separate community forum for the new AX WiFi routers. If you post the question in that forum, people who own that model may have advice to offer.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Gaspi wrote:Hi All
Regards Gaspare
