Misquet
Sep 28, 2021Tutor
Orbi RBK353 AC Adapter
Hi,
Looking for a while now for a third party alternative AC Adapter for Orbi RBK353.
Any suggestions, as I am complete newbie?
Bought a set without the ac adapters and waiting for it to arrive.
As I understand I need the Europe version: 230V, 50 Hz, input
(output): 12V, 3.5A DC output.
Can anyone also tell me the diameter/size of the plug/connector?
Thank you and regards
All my orbi devices (SXK30, RBK43, RBK53) use the same 12v plug with a 5.5mm diameter and 10mm long plug.
I checked a couple of my other 12v devices from netgear and the couple I checked use the same 5.5 x 10mm size.
My netgear devices that run off 19v user a large plug diameter.
1 Reply
