Mocs123's avatar
Mocs123
Orbi RBK752 - Devices will not connect to satellite
I have a new Orbi RBK752 system with the router on the main level in my office and the satellite in my son's room upstairs.  He has a computer and X-Box hard wired in to the satellite which seem to work fine, but nothing seems to be able to connect to the satellite via WiFi.  The router has 20+ devices connected, but the satellite has none.  His Roku TV nor his Chromebook he does school Zoom's with will not connect to WiFi at all despite the Satellite being in the same room.   The Satellite shows connected with a "Good" backhaul status when I check it online.    What am I missing?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    • Mocs123's avatar
      Mocs123
      Thank you.  Turning the power down to 50% fixed the issue and everything is able to connect.
      • FURRYe38's avatar
        Good to hear. Please mark your thread as solved so others know.
        Enjoy. :smileywink:
