duffymo
Oct 04, 2020Aspirant
Orbi RBK752 No Internet Connection
Xfinity is my ISP. The cable modem connecting to the internet is locating in a room above my garage, connecting to my desktop. I extend wi-fi through the downstairs portion of my house using three of their wi-fi extension pods.
I purchased an Orbi RBK752 in hopes of improving my wi-fi access.
i logged into my Xfinity modem as admin, enabled bridge mode, and restarted the modem.
I powered up both the Orbi router and satellite, connecting the cable modem to the router using Ethernet port #4. I set up the Orbi network using the iPhone app. It said it had no problem getating an Internet connection. I completed the setup and came downstairs to check the satellite. It showed a blue light, which means the connection was strong.
I got on my laptop and saw the Orbi network as a choice for wireless connection. I chose the Orbi network and entered the password. My phone told me that it could see both my iPhone and my Ubuntu laptop connected to the Orbi wi-fi network. It looked like I'd done everything correctly.
I was disappointed when my laptop could not access any web pages. No hosts could be resolved; no DNS server was visibile. It was as if there was no connection to the Internet, in spite of the feedback on my phone.
I had to disconnect and turn off the Orbi router and satellite and restore the Xfinity extenders to restore Internet access.
What did I miss? Why couldn't my laptop find a DNS server when the network said an Internet connection was available?
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Power OFF the ISP Modem and RBR for 1 minute. Then back ON with the modem first, then the RBR. Be sure to use port #1 on the modem for the RBR ethernet cable.
- duffymoAspirant
How to move a question? Copy, paste, and create a new question? Or is there a better way.
Already did all that. No joy.
- duffymoAspirant
Xfinity voice and data modem:
CISCO DPC3941TSerial #: 48F7C0D3CE0D
Firmware is up to date.
Your ISP modem already has a router built in. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeTry option 3 first to see if this works.
Be sure your using a good quality LAN cable between the modem and Orbi router. CAT 6 is recommended.
Be sure you use LAN#1 port on the back of the modem...
