lostpty
Feb 20, 2022Aspirant
Orbi RBK752 Public IP Connection Issues with Grandstream UCM6202
I have an Orbi 6 (RBK752) WiFi Mesh System in my home network. Recently I purchased a Grandstream UCM6202 IP PBX. I have been able to configure the device properly to work within my network without any issues. I am trying to confirgure the system in order to connect my devices outside my network (remote IP phones and Wave Lite smartphone application). I am trying to configure the Public IP on the UCM and the port forwarding on the Orbi 6 WiFi platforms, but am not able to reach my external devices. Do you have any recommendations of how I should configure the Orbi in order to reach external devices on the Grandstream UCM ecosystem?
Note: I would like to note that I have a similar system at the office that works as described and am trying to get my home system to do the same.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- lostptyAspirant
Orbi Router Firmware Version: V4.6.5.14_2.0.54
Internet Provider Modem: Arris TG2482A
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #1 first, if not, #2...
