Ff25m2's avatar
Ff25m2
Follower
Apr 24, 2024
Orbi RBK753 connection through switch
I am looking to set up my orbi and connect satellite through a switch. I'm confused about IEEE. I'm thinking of purchasing GS316P for use. I need a switch as I will be adding security cameras using POE at a later time.
  • CrimpOn's avatar
    CrimpOn
    Ff25m2 wrote:
    I am looking to set up my Orbi and connect satellite through a switch. I'm confused about IEEE. I'm thinking of purchasing GS316P for use. I need a switch as I will be adding security cameras using POE at a later time.
    The key is that Orbi satellites must appear to be connected to the LAN ports of the Orbi router.  There have been any number of posts describing how a switch is located at a central wiring hub with the Orbi router and satellites in different locations with only a single Ethernet cable installed to each location.  This leads to disappointment.
    If the switch is connected directly to one of the Orbi LAN ports and devices (satellites, cameras, etc.) are connected to the switch, that should work fine.
